Re: Fuel leak on 76 Johnson 115
Usually they leak from the carb end of the fuel hoses which are centered under the carburetors and just about impossible to reach without removing the carbs. (Murphy is in ecstasy with this problem, and maybe somewhat optimistic.) <br /><br />Try to squeeze a little steady pressure on the fuel line and see if a little fuel is leaking out there.
