Fuel leak
i was out tinkering with the boat today and noticed a leak where the connector attaches to the male connector on the motor,am i correct in assuming the o rings are probably worn on the female side of the connector.<br /><br />Thank you
o/b tech
Re: Fuel leak
This is a good possability as the o-rings can become knicked during usage as well. The cost to replace the fitting is relatively small and would be a good idea.If fuel is able to leak out than air is able to leak in that may cause damge to the powerhead. Also check to make sure that when you last clipped it on that is snapped into place. Hope this info helps.
