fuel line "o" ring connector?
Chacer
I don't see one at the motor end; a boat buddy mentioned that could be the reason she bogs down (70 Johnson) at WOT, starved for fuel...he mentioned the o-ring could be cracked...don't see one...should I just replace entire line...already replaced the primer bulb...thanks all....
wilde1j
Re: fuel line "o" ring connector?
Fuel line w/ primer is <$20 at Walmart, go for it.
Chacer
Thanks; true, it isn't that expensive, but the aggregate is getting there......just trying to find the problem..have already replaced 25 gallons of fuel, primer bulb, screen, plugs etc....
steelespike
CH, Starving for fuel can be a little difficult to find problem Start with a manual..Bad connector(where o ring lives)<br />could be a problem at motor and tank.<br /> You should check supply from pump to carb if supply to carb is good you may have to rebuild carb.If poor rebuild pump.<br /> I usually check everything from tank to carb.<br /> Check clean and rebuild as necessary.Dont forget<br /> vent and pickup tube in tank.
Exjake
If you need to replace the O ring is easy, but its even easer to replace the whole hose fitting clip assy. To replace the O ring, push the ball in a little, then with a bent paper clip work the O ring out. They are cheep at your OMC dealer.
