Re: Fuel Line on a 60hp Johnson
Jughead,<br />Hi and welcome to the forum.<br />I imagine you are going to get many replies on this topic.<br />OMC fuel line = 3/8" usually. <br />Path of fuel to motor: Fuel tank to fuel line to primerbulb to fuel line to hopefully an inline filter to fuel pump to carburetor(s) to motor.<br />Too big of a fuel line may cause insufficient fuel pressure. Pump fills the carburetor bowls. Carburetor should regulate how much fuel is entering the motor, NOT THE FUEL LINE. Too much fuel in the motor would flood the motor and cause it to not run correctly, too little would cause it to starve and not run correctly.<br />Possible causes of scratches: Poor repair and assembly, insufficient oil in fuel mixture causing lack of lubrication, timing set wrong causing binding and or pre-detonation and blowing 1 or more rings, overheating and numerous other possibilities.<br />Hopefully you got a warrantee with this rebuild.
