CATransplant
- Feb 26, 2005
- 6,319
You can get the fuel line from any marine supply place, or even WalMart. You want standard OMC fittings. It's easier just to buy the whole set, with the fittings already installed.<br /><br />I'm not quite sure what you mean about the manual starter. Does the rope only pull out a little ways, then stop completely? If that's the case, you're going to have to find out why. <br /><br />It could be in the recoil starter assembly, or one cylinder may not be able to move properly. <br /><br />You're obviously just getting started on this outboard business, so there's a lot to learn.<br /><br />You can turn the motor into an electric start model, but I'd advise making sure it's a runner before spending any more money on it.<br /><br />As always, on this or any other forum, the more information you offer, the better the help will be. The recoil start problem is a good example. Saying it's "a little tight" just doesn't provide enough information. Manual starting a 15 hp motor is always a little harder pull than starting a lawnmower. If the rope will pull out it's full length, then the engine is not locked up. <br /><br />Let us know the details, and I'll bet we can get you up and running.
