fuel line...pump to carb
kewlkatdady
I know I see a lot of debate about whether or not this line need to be steel or USCG approved hose.
I'm not here to debate that....
I'm having an issue finding the fittin that is inverted flare that goes from 3/8 to 3/8...the closest I got was 3/8 standard to pipe thread...wont work obviously...
Edelbrock 1409 carb
I've been able to put a couple of fittings together and "make it work" but then I run into clearance issues with the shift linkage.
I've messed up 2 fuel lines by trying to make the 90* short enough to clear the linkage.
I've been to 10-12 stores looking for a solution in fittings.
Unless I can figure this out...hose it is.
Can you help me?:mad::confused::mad:
kewlkatdady
Re: fuel line...pump to carb
speed shop...hmmm....didn't try that.
Thanks.
