fuel line types?
slikkrikk
I have a 1987 Wellcraft 23 Fish w/2.7 Sea Drive. I am replacing fuel line from the tank to the motor & was wondering is there any difference in automotive rubber fuel line & marine rubber fuel line? Thanks for any help
Bob_VT
Re: fuel line types?
I do believe that marine lines have a uv resistance (they tend to see more sunlight then when in a car) and you should also make sure they are alcohol resistant.
Bob's Garage
If I am not mistaken you MUST use A2 (or A1 as an alternate) rated CG approved fuel line, fill hose, and vent line.
If the CG pulls a safety inspection on your boat, or anyone else for that matter, they can, and the CG will, shut you down and make you walk to your trailer.
Seriously, automotive lines leak fumes, and in an enclosed compartment, like a bilge, can be the fuse to a bomb.
DO NOT USE automotive ANYTHING on your boat.
Unless of course you don't care about your life and the lives of everyone around you, then go ahead.
We will read about you on the net, and in this forum!!
dingbat
http://newboatbuilders.com/pages/fuel.html
Fuel Hose:
When fuel hose is used it must be either USCG Type A1, USCG Type A2, USCG Type B1 or USCG type B2. Where you use it determines what type you use.
From the fuel inlet on the engine (usually the fuel pump) to the carburetor you must use Type A1 or A2.
Each fuel vent line or fill line must be USCG Type A1 or A2 and the line from the fuel tank to the engine inlet must be type A1 or A2;
As a practical matter, few boatbuilders want to have to stock two types of hose, so most buy only Type A1 and use it everywhere. This is fine. Just be sure that you put in your owner's manual that the hose from the fuel pump to the carburetor and the vent and fill hose must be TYPE A1 or A2.
So what is the difference between A1, A2, B1, and B2? First the difference between A and B. A hose has to pass the 2 ? minute fire test, B does not. The theory is the A is under more pressure than B, and being on the engine is exposed to more danger of fire than B. Since B is between the pump and the tank, if a leak occurs, the pressure rapidly drops to zero and the pump just sucks air, stopping the engine. Fuel doesn't get sprayed all over the place. With Type A, since it is between the fuel pump and the carburetor, it is under pressure and there is the potential that fuel will be sprayed around.
The difference between Type 1 and 2 is the permeability. All hose allows a small amount of vapor to pass out through the wall of the hose. The more permeable the hose is, the more vapor passes through. A1 and B1 pass much less than A2 and B2. About 1/3 as much. The Coast Guard Sets the standard for the amount that is allowed.
gss036
I just had to replace a John Deere lawn mower line, I kept smelling gas and the engine not running proper, I could see some checking on the exposed part close to the carb, I twisted it and it almost came apart from SUN exposure, auto fuel hose would do the same on a boat, so be sure to follow the above advise, may coast a couple bucks more but well worth the assurance you have the correct product.
