FUEL LINES BAD???? FUEL ISSUES??? BOGGING DOWN?? READ THIS..
Ant-Knee
Hello To All,
I thought I would share some info that just may help someone out there..
I own a 98 merc 150 outboard V-6, S# 0G740674.
Long story short..
I had an issue that I knew was fuel related,
I rebuilt the carbs a few times, Rebuilt fuel pumps, Changed fuel filters, Fuel water separators. Primer bulbs
Went through the entire fuel system to no avail.. Just could not find my issue.. Just when I was gonna start going through the ignition
I figured let me check all the little bleed lines, The real small ones.. Well when I was done checking them and making sure they were all connected
I looked down at my hands and they were all black, I thought to myself, Where the hell did this come from??
Well it turns out it all rubbed off the bleed lines to my hands..I thought, That cant be good.. Then I rubbed my hand over the fuel lines, and the same ****..
So I decided to change all the bleed lines and fuel lines and walla, Problem solved..
Turns out the problem was the fuel lines and bleed lines, I did the carbs several times, But never thought bout the fuel lines, as they looked great.. They must have been breaking up inside and clogging the jets in the carbs , Even right after carb rebuilds....
If you are battling a fuel issue and just can't track it down, Don't over look the fuel lines along with bleed lines... I would never have thought they were bad at all bye just looking at them..If I did not realize the black on my hands I would still be trying to find this issue...
Thanks,
Ant..
yzf125
Would also be helpful to include your symptoms you were having at the time as to help others, glad you found your problem.
Ant-Knee
Sorry bout dat...
Problem I was having was a mid range issue,
with a slow smooth throttle up at about 1800 - 2000 RPMS engine would bog down and die.....
If you hit full throttle real fast, Then it would power through it and be fine..
Here is a video..
https://www.youtube.com/watch?v=YJVGu751n_o
zul
Great video. I'm having a similar problem. When you say 'bleed lines' which lines are you referring to?
yzf125
They are small crank case vent lines and they have small check valves on them.
Ant-Knee
Here is a pic...
This is my 98 merc 150,
Not sure what motor you have...
Thanks,
Ant...
