Keyboardman
- Sep 10, 2015
- 360
Hi guys, I finally found the factory service manual for my 74 50hp Johnson. According to the manual, the fuel line from the pump should go to the top carb and then the bottom one. On my engine, the fuel line goes to the bottom carb first then up to the top carb. Looks like I'd need to change the float bowls around to make it like the original configuration. I'm still working on a slight miss/sneeze with this engine. Could the fuel line situation be part of the cause??
