fuel lines?
Haus
does it matter what kind of fuel lines i use in the engine? the original black rubber lines on my 53 10hp are starting to dry out and crack. could i use clear fuel lines? or do i have to use the black stuff? im still running the the original pressure tank, can i replace the tank lines with the clear stuff aswell? or is it all the same? i have a bunch of the clear line from a BRP dealer that i used on my snowmobile, is it safe to use? i dont want to blow a line and have an engine fire out on the water
Thanks
