Fuel management
Chrsamss
can I see fuel consumption on a 2005 f250tur. Currently there is not a meter however reading through the manual it shows one, I have a Raymarine E127 and was hoping to get connectivity that will show my active fuel management. Does anyone know if this is possible and how to achieve it thank you
Only if a fuel sensor was added when the electronics were installed. The fuel sensor is optional and not everyone uses them
99yam40
some of the newer motors have ECU s that can estimate the fuel usage by the firing of injectors over different loading.
Maybe you can find someone that knows what you motor can do
