Fuel mix forgotten
John McFarlane
Ok I know, what a dork. But I have forgotten if I added the 2 stroke oil to a plastic tank of 25 litres of fuel. Is there a way to tell if the oil is in there. If I add another lot it will end up at 25:1 instead of 50:1. Engine is a 79 Johno 70hp. Many thanks.
Bob_VT
Re: Fuel mix forgotten
Color. The gas will look tinted dark blue just compare it to fresh gas. If you happen to "double the dose" of oil it will still run and just be extra lubricated. You will get more smoke for that tank too.<br /><br />Bob
Solittle
John - I would add to be on the safe side. Bob's advice may not be good down under if your fuel is a different color than ours. As he said it won't hurt.
Dunaruna
Spot on solittle, our regular unleaded is purple/blue.<br /><br />Double dose is better than none or start with a fresh load.
Boomyal
If it'd be me, I'd dump it into your old beater the refill and remeasure the oil. If your beater is carbuerated it won't mind the oil mix. Your two stroke won't particularly care for a double dose of oil.
ZmOz
One tank of 25:1 won't hurt anything. Might make the plugs a little dirty...clean/replace them after you're done. Believe me, one tank of 25:1 is WAY better than one tank of 1:0. :D
JB
Outboard non-repair topic.
Dhadley
I agree. It won't hurt a thing. It happens way more than you think, dont beat yourself up about it.
BillP
Like already posted, it isn't an issue. Just expect a more smoke. Unless you idle long periods the plugs won't see it with one tank either.
