Fuel Mix Ratio
Todd Ferguson
I recently purchased a 1991 Bayliner Capri with a Force engine. The previous owner described this engine as an outboard motor mounted as an inboard.<br />It has a lower unit just like an inboard and the rest of the motor is housed in a compartment in the boat. My question is what is the fuel/oil mix ratio and what type of oil would you recommend?
Deerdog
Re: Fuel Mix Ratio
What you have is an L-drive, a not so successful experiment Force came out with in the early 90's. I believe they were 120-125 hp only and were opn Bayliner Capri's of that time. <br /><br />It is essentially an outboard powerhead and an I/O outdrive. The mix is still 50 to 1 (a pint of TCW-3 oil to 6 gallons (actually 6.25) of fuel).<br /><br />Best of luck to you.
