Re: fuel/oil mix for '56 Johnson 5.5 and '56 Merc 25E
Hi Tallcar,<br />OMC once put out that you could run any engine that they made on a 50/1 mix if the engine was first de-carbonized. I personally have run several older engines on a 50/1 mix with no problems. However I think that most folks on this board will tell you that you need a much richer mixture. The Mercury I think, always had needle bearings, so I believe that a 50/1 ratio will work there also. All that I have to back me up on the above is a set of notes taken at an OMC school in 1972. I wish that I could find the service bulletin that they put out, but over the years a lot has gotten lost, or not updated properly.<br />Hope that this helps
