I recently aquired a 1954 Johnson Sea Horse 10Hp motor (Model# QD-15). The motor, which uses a 24:1 fuel
il ratio, runs great, but the exhaust leaves a minor oil slick when the engine is running at idle in neutral. With today's new oils, can I go to a 50:1 ratio? Has anyone actually run an old motor designed for a 24:1 ratio at higher ratios? I've had some feedback from some other postings saying it's no problem with the new oils, but I'd sure like to hear from someone who has ACTUALLY done it!<br />Any feedback would be greatly appreciated.<br />Thanks!<br />Fishcamp
