FUEL PRESSOUR
man-of-war
HI, the engine is a 454 7.4L V8 GM 1975 i hooked a fuel pressour gague to the fuel line to the carb. my question is, the pressour in the fuel line should stay up after the engine has been shut down?......THANKS
Re: FUEL PRESSOUR
Well,........... In Theory,+ By Design,........Ayuh,... I'll Agree.............. ;) <br /><br />But,......<br />My Experince is,.......... I've been Sprayed,.. or Doused with Gasoline on More than 1 occasion,.. <br />When removing the Carb. Inlet line off a Carb. that hadn't run in Awhile..............<br /><br />I Always Pump a Carb. a few times Now,........ Just to relieve the Pressure :D off the needle valve...........
