I think the cause of my black smoke when I go to start the boat after it has been running is my FPR. I cant find it tho. what I think is it, doesnt look like any of the new ones. Can anyone tell me where to find it on the 1996 Larson 220 SEI , 5.8L FL PHUE. I think its the Ford engine b/c the spark plugs are a pain to change and I had to remove the exhaust manifolds.
Out drive is the Penta SX.
I just rebuilt the carb today so i have not tested that. Replaced and took apart everything but the butteryflies.
The black smoke might also have been caused by my coil, which i thought was bad. Engine starts up on first crank when cold. but when hot the longer it sits 5-30min the closer it gets to not starting. If i start it right up after turning it off it starts back up ok.
Anyways I put a fireball coil in today as well.
I have a pick of what I think is the FPR, but its connected to the intake manifold, and on that line it T's off to the PCV Valve which is plugged into the Valve Covers.
Then I think the outlet or exhaust of the FPR is connected to the exhaust on the back of the engine... ???
Is that it above? It has a screen on the right side which is weird. If not what is this thing.?
