fuel problem 57 johnston 18
kenrahe
:confused:got a 57 and it looks like the person before tried to do something with the fuel line i can tell where the one to the filter goes to the fitting but it looks like there are two brass fittings on the motor for lines i'm not sure which one connects to the fitting to send pressure to the tank there is one behind and below the carb and looks like one was added mid block could someone tell me the right one and should the other one be blocked off any picture off proper running of the fuel lines from engine to filter and from filter to fitting would help greatly
Joe Reeves
Re: fuel problem 57 johnston 18
There is a fitting at the center bottom portion of the intake manifold, this is the one that feeds pressure to the fuel tank.
Suggestion... When posting, insert periods, question marks, whatever where they belong. Your post took some figuring out as it is just one long statement which results in confusion.
