BluefishBuster
- Sep 23, 2004
- 19
I'm new to outboards and am having a problem with my Johnson motor. When attempting a cold start, I pump the primer bulb (pressurizing the fuel line) but can't get the motor to start. Then, if I remove the engine cover and bleed the line (there's a valve on the fuel pump), while pumping the primer bulb, and close it off (in effect, priming the entire line), I get the motor to start. Motor then runs fine until I shut it off for a length of time ... then has problems starting and remaining running. Any hints? Thanks a bunch.
