rlb9844
- Jan 27, 2010
- 82
Last couple of times I've been out I have had the same problem. I have an '79 Evinrude 150 that I always start before leaving home. On the muffs it starts and runs fine. When I get to the lake it runs great for myabe 15 min. Then it acts like its giving out of gas (running at 3/4 throttle the motor just dies back but doesn't die completely). I've tried swapping to my back-up fuel tank, same thing. I have an inline fuel filter between the fuel pumps and carbs. The first time this happened I looked and the filter was only half full of fuel. On closser inspection I noticed I had the filter up side down. Hooked up right (IN and Out) but the "out" was on top. With the motor running you could give it some throttle and the fuel level in the filter would go down. Let off and it would come backup. So I mounted the filter right side up. Now it stays full of fuel. Again ran it on the muffs, even goosed it a couple of times. Filter stayed full. Get to the lake. Same thing. After about 15 min of tubing it starts dieing back. At one point it died completly. Hit the primer bulb a couple of times, it fired right back up. This time the fuel filter was full but it looked like it had an air bubble on the inside of the filter element. I've had the fuel pumps apart and eveything looks good. Any ideas. Do I need to rebiuld the fuel pumps, or is it something I'm missing? Any help would be great. Tried to find a picture of the filter for clearification but no good. Basiclly its a glass tube with a filter inside.
