2000Johnson90
- May 2, 2009
- 13
I have a small but frustrating problem and before I just start replacing parts, maybe I can get some advice. I have a 2000 Johnson 90 Ocean Pro. I pump the bulb and it starts right up on muffs and idles just fine for about 3 minutes, then starts to bog down, shortly thereafter stalls. I feel the bulb and it is empty but not flat. When I run it and it starts to bog down I can keep the motor running by pumping the bulb quick or by increasing the throttle, after I pump the bulb or back down the throttle, it will run for a few minutes and eventually bog down and stall again.
I have replaced all fuel lines, checked the vent, and added new gas, and get the same problem and behavior. Does anyone have any ideas? I'm thinking it could be a weak fuel pump, running fine with the line fully charged, but doesn't have enough to keep pumping enough fuel.
Again, it starts right up and runs fine for about 3 minutes, and the bulb is empty when it stalls, when I pump the bulb and turn the key, it starts right up and does the same thing again.
Any help is great, thanks.
