txflood
- Jun 30, 2008
- 7
I have a boat with a 1996 Volvo Penta 4.3GS that I'm having troubles getting started. It does have gas in the tank.
After reading this thread, I had some questions I was hoping someone could help me with.
It doesn't seem to be getting any gas up to the carb in my case and one thing I didn't check is to make sure the fuel filter was completely full of gas. I was wondering then if these type of fuel pumps can't self-prime and it is required for the fuel filter/separator to be full.
I have attached a pic showing the way the fuel pump is mounted on this engine. You can't see it but the black circle below the pump is where the filter mounts. The pump is basically drawing straight up out of that filter.
The other thing that I tried during my short investigation the other day was detaching the hose going down to the tank. I opened the fuel cap and then blew air down the fuel line hose going to the tank with my air compressor just in case of a blockage that way. I did hear bubbles in the tank, but the fuel line hose was quite rigid, lots of pressure to get that air in there. I don't know much about boat fuel tanks other than its a vent system, so does that seem normal?
Thanks
Thanks
