elwilliams13
- Jul 4, 2003
- 137
Have a 91 rude 225 vro is disabled. engine runs good. have a dual tank setup on a 79 mako, boat did not come with anti siphon valves only a wire mesh at the connection from tank to line. At 4000 rpm and above primer bulb collapses due to vacuum from the fuel pump. tested this and it pulls 5 psi at idle. I can feel the limiter pulses at the primer bulb at 2500 rpm. the filter is a racor and is full of fuel at all times. I don't get it! vents are working properly all I can come up with is tank debris,Any suggestiuons.
