rgirandola
- Mar 13, 2005
- 3
I am having major problem with my 5.7 mercruiser...the port engine is not pumping gas to the motor. I've changed up the fuel line system, replaced the fuel pump, replaced the fuel/water seperators,swithced the fuel line from the starboard engine to the port and the port engine keeps dying(the starboard engine runs great). The cam looks good on the port engine. If you manually put gas in the carb, it runs fine until the gas is all gone. Even isolated the fuel system with portable tanks and a clear hose and it still isn't pumping gas to the motor...someone help????
