Re: Fuel Pump and High Pressure Regulator
I found this old post that explains the issue:
I had the issue on a new boat that I just got. It's a 2004 Four Winns with 8.1's. it happened when I tried to deliver the boat after it had an 18 month layup. I was so upset by the predictable problem, I called VP. Much to my surprise, I was able to get an engineer on the phone. I asked him what the real deal was. Here is what he said...
First, the pumps are made by Carter and are designed to be non-serviceable so we don't blow ourselves up trying to fix them. I can live with that...
Second, the issue IS caused by ethanol over a period of time. When the gas is allowed to sit, the ethanol separates from the gasoline and becomes concentrated enough to peel the paint. He told me that the further north you go, where the layup is longer, the more issues the are. In the south, where they use the boats year-round and gas does not sit in boats for a long period of time, this never happens.
He told me candidly that the best way to store boats now in the off-season is to store them as empty as possible with stabilizer. The condensation fears are a non-issue compared to the ethanol issues. He said that the minimal amount of water that would develop in the winter would be burned off immediately when the engine is run the first time.
Since I am an "in-water" winterizer using a bilge heater, he told me that running the engine every 2 weeks wil take care of the water, coat the cylinders and preserve the oil by killing the acid that forms which is the real reason oil should be changed.
Sounded like he knew what he was saying...
