Fuel pump for 9.9hp 4 stroke
roehrle
Looking for a lay out of components in the 0435352 fuel pump . The part where the diaphram is located. there is about 1/2' spring. Are there 2 springs,one on each side of the diaphram ?? There is a smaller spring on the plunger. I have the shop manual and it isn't of any help. There is a diagram that shows the front of the pump where the gas enters. I want to see the parts when you pull the part that is next to the plunger behind the diaphram.
