fuel pump issue
mikeheron
here is more info boat is a 1997 searay 185 engine is a 1997 mercruiser 4.3 sn 0k157041 it is carbed, my fuel pump does not shut off when the ignition is turned off. there are no relays that i can see only a 50 amp circuit breaker near the ecu. ive reset it and no change. i also just change the ignition switch and i still have the problem. any ideas? boating season is a month away and i want to be ready.
JUSMARCEL
Re: fuel pump issue
There sounds like a short between switch and pump. take yur 12 volt tester with switch off and start at pump find where power is coming from. hope this helps, Marcel
Faztbullet
Re: fuel pump issue
Either the oil pressure switch is stuck closed or fuel pump relay stuck...its on the plate where ignition module is and looks like below.
oops!
Re: fuel pump issue
lets say we just move this to the correct forum
Pete104
Re: fuel pump issue
You saying this ain't a merc problem? That means you know it's a boat problem! Key switch bad? Being a Sea Ray, that's merc.
achris
More fish than mountain goat
Re: fuel pump issue
It was in the outboard section, Oops! has moved it to the I/O section...
The only way you can be getting power to the pump with the key OFF is if there is a short in the starter motor slave solenoid.. Or someone has hard wired the pump because of the usual problem with the oil pressure switch....
Is this a new boat to you? or is this a fault that has just started on an engine you have been using for a few years...?
Need some history.
Chris.......
Pete104
Re: fuel pump issue
Thanks for the heads up! Didn't see it coming.
Carry on!
mikeheron
Re: fuel pump issue
the boat is not new to me just started and the end of last season
