Fuel Pump Issue
DJB19
I have a 1979 Evinrude 150 XP outboard motor. It seems like it is not getting gas when I try to start. I want to buy fuel pump repair kit but it seems that every website (Crowley Marine, Evinrude, and etc.) gives me P/N 0393103 for the kit. I believe the upper fuel pump assy is #038855 and lower fuel pump assy is #0389440. But it the description the repair kit is for 1979-1983, 85 thru 140 HP. My confusion is that I have a 150 HP, premix gas/oil.
Will the repair kit (#0393103) caskets fit?
Will it fit both fuel pumps?
Do I need to repair both fuel pumps?
I want to buy the correct kit.
Thank you in advance for any info/knowledge/wisdom. Also hope you have a great Labor Day weekend!
I can also send small video of me cranking the motor. If you need/want to watch it not start. My fuel issue is ONLY a little educational guest.
Again THANKS....
David
DJB19
Model # on title is J150TLCTE. Model # via Evinrude website is 150949C.
flyingscott
Look up parts for an 83 model which is what yours comes up as. I found your model # right away
DJB19
I just look it up. So my Evinrude is an 1983? I relied on the boat title to be correct.
Thnks
flyingscott
Your title has the correct model #. I don't know where you got the other one.
DJB19
I was looking up the wrong year, then each website would give me the other model numbers. Which was wrong but I never thought to look up different years. I am extremely new to boat motor maintenance.
flyingscott
On OMC products the model # tells you the years. Just type in your model # from the title.
