mclothier3
- Feb 12, 2013
- 43
I am in the middle of getting a 1995 Johnson 50 running after sitting for the last 4 or 5 years. Ive replaced the water pump, kitted the carbs, replaced fuels and oil lines, etc.
The motor does run, but Im having issues. It fires right up and seems to idle fine, but out on the water... anything over 2000 rpm and it dies out, like its starving for fuel. I can push and hold the ignition switch and that helps keep it running. I can run it in the driveway on the muff and it does the same thing, idles fine... bump up the rpm to 3000 and it runs ok for 10 seconds, then speeds up and dies out. I even made sure the fuel was getting to the pump by pumping the bulb to keep the fuel filter full.
Im assuming the original VRO pump isnt working like it should. I checked the pulse limiter and it looked very clean. I know there are certain checks that can be made to determine if the VRO pump is working or not, but at this point I think Im done with it. I dont want to spend any more money on it not knowing if it will work or not. and if it isnt... Im not spending $400 or more to replace it.
So I ordered a regular non VRO pump and it should be here sometime next week. I have looked at the VRO conversion thread and still have questions.
Ok so I remove the wiring to the VRO pump and the two wires going to the oil tank... by doing that, will it disable the warning horn for overtemp? Im assuming that removing it will just disable the VRO warning beeps.
Anybody have a better explanation or picture on how the fuel lines should be? Assuming from the fuel inlet fitting, I should have a line going direct to the inlet side of the pump, then another from the outlet side of the pump to the inlet of each carb, what about the fuel primer system? Should I also use the separate fuel filter or just rely on the filter screen in the new pump?
Thanks for the help!
