Needing help finding issue with electrical circuit to the fuel pump. Problem came out of nowhere. Boat has been running good with no issues for most of the season so far. Yesterday started the boat in, while still warming up in the marina and the TKS choke engaged the motor just stopped. After some looking around found a 15 amp fuse in the helm was blown.
No power to the fuel pump when starting or after running. I have hot wired the fuel pump to make it run.
If I try to start the engine with the oil pressure switch plugged in the fuse blows again. Could this be as simple as a bad oil pressure switch? Could it short to ground if bad?
Please help as we have a big trip driving pulling the boat across country to lake Powell that I am trying to get prepared.
