Hey, I was wondering if I could get some help. Last season my oil pressure sending unit went bad, so I jumped the wires for trouble shooting. This provided enough voltage to power the fuel pump and every worked fine. I started working on it this winter with a new oil pressure sending unit, but havent installed it yet. Im not getting enough voltage at the fuel pump.
Fully charged battery reading 12.4 volts
with the ignition switch on I get 9.5 volts at the fuel pump
when turning engine over its still 9.5 volts at the fuel pump.
if I check voltage at the sending unit its 10.4volts.
i have jumped the fuel pump and it works, any ideas on why im loosing voltage?
thanks guys.
thanks guys.
