Fuel pump pressure question
WJL24
I'm finally getting my boat ready to use and I noticed that the clear fuel filter almost runs out of fuel while idling for a long period of time. I disconnected the line (there was a hiss indicating pressure) but when I cranked the motor over it spurted gas but not steady. Is that normal? is there a way to check the pressure?
1986 OMC Cobra 5.7 liter with a quadrajet carb and mechanical fuel pump.
Re: Fuel pump pressure question
Ayuh,... Welcome Aboard,... Plumb in a gauge, it should show 4 to 6 psi,...
That clear filter shouldn't even be there,....
If ya don't have a canister type filter, before the fuel pump, Add 1, 'n get ridda the clear thingy,...
Maclin
The fuel flow will not be steady, it will go in spurts as the mechanical pump's lever moves in and out, one stroke pulls some in and the other forces it out.
