fuel pump pressure
mort kent
1988 force 50 hp, how much fuel pump pressure should you have at the carb????????
foodfisher
Re: fuel pump pressure
I don't think you're fuel injected. The fuel pump just keeps the bowl full. Vacuum from the pistons suck the fuel out. Or am I missreading your ?.
roscoe
I've never seen a spec on it, nor measured it.
Should just be a steady stream, 2-3 lb of pressure, so as not to blow past the needle valve.
