fuel pump pressure?
vrodrig
Whats the fuel pump pressure specs at idle and at higher rpm (2500) for the suzuki DF70 1999 mod. I dont have my book yet but its on its way, Amazon.com has the service manuals 20 buck not bad! :D
clanton
Re: fuel pump pressure?
36 pounds at idle, regulator should hold 28 pounds for 5 minutes engine off.
vrodrig
Thanks again Clanton for coming to the rescue! You sure know how to treat a fellow boater when he is with no service manual. I will be getting my manual this week :D
99yam40
Strange, Brownspoint does not even list a DT70 but they do a DF70.
Are you sure about the model #?
I take it you are asking about the electric pump on the DF70 and not the lift pump
vrodrig
Yep, I am asking about the electric pump on the DF70, not the lift pump. Yes, my bad, it is a DF not a DT. Thanks againg Yam. I will correct that on my first post, so not to confuse anyone if thay are looking for the same model # needing specs.
