Crazyman1225
- Apr 7, 2010
- 72
I am working on a 2001 Wellcraft, model 22 Walkaround I/O. I helped the owner put a new motor in the boat. It is a GM V8. The issue now is that the fuel pump (electric) does not activate when the key is turned on to first start the motor. The only way to activate the pump is to have the key in the cranking position, then the pump will run. Everything appears to be connected correctly. Is it true that the pump has to be tied into an oil pressure switch to function properly? Any help would be greatly appreciated. Thank you.
