Fuel pump psi numbers??
Levie17
Anyone know of, or where I can find the output numbers for my fuel pump?
2002 125
Texasmark
My manual for that/my engine shows the pump output pressure:
WOT: Min-Max 3-10 with 8-10 PSI normal.
Idle: Normal 2-3 with 1 being minimum.
Fuel pump suction measured with a vacuum gauge Teed into the fuel delivery line to the engine is 2.5" Vacuum increasing slightly with RPM increase....more vac.
It also says that the pump is designed to lift 5' with a 5/16 fuel line but connectors and other things along the way can reduce that distance......5' vertical lift is a lot more than I thought it's capability.
Levie17
Thanks. I’ll have to do a WOT run to see if the pump can keep up.
