i have a 470/170 mercursie<br />what would happen if you used a fuel pump that psi is higher.
W Westdevil Seaman Apprentice Joined Jul 30, 2003 Messages 48 Jul 1, 2004 #1 i have a 470/170 mercursie<br />what would happen if you used a fuel pump that psi is higher.
Bob_VT Moderator & Unofficial iBoats Historian Staff member Joined May 19, 2001 Messages 26,084 Jul 1, 2004 #2 Re: fuel pump psi/to high Put a regulator in line with the feed line befor the carb. Your only risk is the fuel line where you run higher pressure. <br /><br />Bob
D DHPMARINE Captain Joined Dec 16, 2003 Messages 3,688 Jul 1, 2004 #3 Re: fuel pump psi/to high Just curious,but why would you want higher fuel pump pressure?<br />DHP
