I am getting ready to rebuild the fuel pump and replace the exhaust plate gaskets, they are starting to leak, on my 1996 75hp Force outboard. Is there anything I should watch out for when rebuilding the fuel pump? And should I use a gasket sealer for the exhaust gaskets, and if so, what type should I use? Also what is the torque spec for the exhaust plate bolts? I would hate to break one of those off.
Thanks,
JD
Thanks,
JD
