fuel pump sight tube ?
kussfamily
on the bottom of my fuel pump I have a third line, its a short black hose that has been cut and there is a screw in the middle of it, so nothing comes out. I have no sight tube running from my fuel pump to my carberuator. I have fuel in my oil. Is what I'm seeing OK, with the third line... How can I tell if my diaphram has a hole in it causing gas to go in the block ? my carberuator has only clean fuel in it...no oil.<br /><br />-Rick
magster65
Re: fuel pump sight tube ?
My guess is that your diaphram has a hole in it and someone plugged the line that's suppose to go to the carb instead of replacing the fuel pump.
kussfamily
knowing the stuff above...how do i check to see if the diaphram has a hole in it ?
magster65
Unplug the sight tube, start the motor and see if any gas comes out. There's not many ways fuel can get inside an engine... the fuel pump or a carb that's flooding profusely.
Yea, I'm with magster65, Only, Don't just unplug it, Put it back the way it Belongs.....
