DamianJP
- Mar 25, 2008
- 612
Working on a XR4 '89 fuel pump and when I dissassemabled it, for the Diaphragms it had two Solid ones.
---Why do I have a hole through the fuel pump base? Seems like the Diaphragm(Solid) against it blocks it.
---Also on the Chamber plate, it had a Diaphragm(Solid) against it aswell. Seems like it's blocking the front brass piece.
Seems like the intructions that came with the fuel pump have this order.
Pump base , Diaphragm(solid) , Gasket , Fuel pump body , Gasket , Diaphragm , Chamber Plate
Seloc Had this order.
Pump base , Gasket , Diaphragm , Pump body , Diaphragm , Gasket , Chamber plate
Which is the right order???
Pictures here http://s281.photobucket.com/albums/kk233/damianjp_photos/Fuel pump schematics/
Plus I didn't have the Diaphragm with Oil mixing holes. What is that one used for? Is that a problem on a oil injected motor?
Could someone shed some light on the subject. Don't wanna block up the oil from getting to engine or something to go wrong.
Thanks,
Damian
Thanks,
Damian
