I have a 350 engine with a mechanical fuel pump from a 1995 350 mag alpha setup. There is a hose nipple on the fuel pump. My older 1979 had no such hose nipple. The old version had a sight glass with a stamped note in it saying "if gas appears in this bowl, replace the fuel pump". Now, on my new edelbrock 1409 carb, there is a hose nipple that is identified as a fuel pump vent. I presume the 1995 setup uses a hose connecting the fuel pump to the carb.
What type of hose connection do I need? what is this for? I know it says fuel pump vent, but none was their on the old style, wondering what changed? Does this have anything to do with the sight glass setup on the old fuel pump?
separate question: the fuel separator has a mounting bracket with an insulator plate. What is this insulator designed to do?
thanks
Ed
thanks
Ed
