further
- Jun 18, 2009
- 1,034
Excuse if this is a dumb question.... would damage be done to the fuel pump if the fuel supply line from the pump that connects to the carb is disconnected and the motor is cranking? Should fuel come out of that line when it's cranking? Once the line is connected to the carb and the throttle is manually opened wide should there be a strong squirt of fuel?
Thanks
Thanks
