Re: Fuel Question?
130 is reasonable compression, but need more info on possible problem. How "around" 130 is around? Does engine run poorly because of the "clean" plug? See, if water is getting into the cylinder and cleaning the plug the engine may run acceptably. However, if the plug is clean because it is not firing, then the engine will run poorly. So, first determine the reason for the clean plug--There's only three: Plug not firing, little or no fuel delivered to that carb (very bad), or water leaking into combustion chamber and steam cleaning the plug.
Now, with 130 on all 3 cylinders, I doubt if the head gasket is bad. If you had a big enough leak to pass water, the compression would be significantly lower. More likely, the exhaust cover gasket(s) would be bad in this scenario. First, see if the cover bolts are loose. If so, tighten them a bit and see what happens. Don't go so tight that you snap them though.
If you do go to replace the gaskets--there are two with a ss plate sandwiched between--be careful with the bolts. They do tend to corrode into the block and can give you trouble coming out. With me it is Murphy's Law all the way. The last bolt always snaps off.
