Fuel Separators
mrom1234567
I just installed 2 Racor water separators with plastic drain bowls. The instructions say to fill them with fuel before screwing them on.<br />If I do not fill them, can I open the drian valve as I prime the bulbs to release air?<br />Or should I fill them with fuel first?<br />These are direct replacements for filters that were there already.<br /><br />Michael
18rabbit
Re: Fuel Separators
If those are diesel fuel filters it is important to get all of the air out of the lines. If you don't it can cause an air bubble to block the injector lines. Gas engines you can just pump fuel thru. Note: the Racor gas filter and the diesel filter are not the same and should not interchanged.
mrom1234567
Re: Fuel Separators
It is gas and my Yamaha motors are carburated.<br />Is it ok to just prime my bulbs until the air is out?
Chris1956
Re: Fuel Separators
Mike, Just prime the motors until the air in the fuel line is gone. It's the same as if you ran out of fuel on a 6 gallon tank and switched to a full tank.
mrom1234567
Re: Fuel Separators
Thanks,<br />I just squeezed the bulbs and they filled right up. Hope this clears up my problem. One of my motors seemed like it was not getting fuel. it seems to run fine now. There was a lot of crud in the filters.<br />Mike
