Caseyuconn
- May 1, 2011
- 61
I just boat a boat with a 1995 88 SPL. It ran great when testing it out one month ago.
I tried to start it for the first time yesterday with a fire and die results.
My question is two parts.
1.) Is it OK that fuel is coming out of the schrader valve when the key is pushed in
2.) Can someone break down the cold start process for this motor, should you goose the throttle, choke continously while cranking etc.
Thank you
- I removed the engine cover, when I push the key in, fuel comes out of the schrader valve. Is this correct?
After trying to start in neutral with throttle advanced I removed the air cover and found lots of gas pooled behind the cover
Thank you
