Fuel smell
I have a 1993 Playtime 20' Bow Rider with the fuel tank in the bow. When taking the cover off it has a bad fuel smell. You have to let it air out for 15+ min before you can get in it. Also, when walking by the port side fuel tank vent, the smell is very strong with the cover on or off. The smell seems to be the same on hot days as well as cool days. I have not noticed any loss of fuel nor can I detect any leakage or cracks down the fuel line.
My local servicer says this is normal. None of the other boats that I have been around have this problem. Any ideas?
cr2k
Re: Fuel smell
If your vent is working you will be able to smell fuel there. With cover on, does the cover come down past the vent and trap vapors in under it?
Normal.
tpenfield
Re: Fuel smell
My idea is that the tank may have a leak. If so, that is a really bad thing in a boat.
26aftcab454
Re: Fuel smell
could you disconnect fuel line at motor- seal vent -& pressure test at the cap?--just an idea.
oops!
Re: Fuel smell
no....it is not normal for the amount of fumes you are talking......there is a leak somewhere.
it is possible you will smell fuel around the vent on hotter days as the expansion will force fumes out of the vent.......but not under the tarp
fuel systems are easy to figure out......you have a filler tube, a vent....and a feed line to the motor. one of these (or all) is bad.
you must investigate
sschefer
Re: Fuel smell
What type of tank is it. There is an acceptable level of permutation allowed on the plastic tanks and they do tend to make you think there's a problem. Your's sounds a little more serious than that. You might consider replacing the fill hose and the vent hose. They have to be red-stripe hose, not just any old thing will do.
Texasmark
Re: Fuel smell
Normal.
Took the words out of my mouth. Grin
Take the cover off and run the vent fan for awhile, turn it off, then give it say 12 hrs and stick you nose at the lowest point you can get to and then ask the question again. If vent as mentioned you won't smell fumes to speak of.
Mark
Re: Fuel smell
Problem solved! I replaced the fuel line from bow to stern and rebuilt the carburetor. The plastic tank is original and that will be my next (major) project.
shrew
Re: Fuel smell
I think you are going for PERMEATION
Permeation: in physics and engineering, is the penetration of a permeate (such as a liquid, gas, or vapor) through a solid, and is related to a material's intrinsic permeability.
Permutation: In mathematics, the notion of permutation is used with several slightly different meanings, all related to the act of permuting (rearranging) objects or values.
Fuel tanks should be non-permeable. If you smell fuel vapor it is because of a fuel leak and you should identify it, and resolve it before you use the boat again. I hope you're not storing that in your garage.
