I bought a 1999 Yamaha F 9.9 4-stroke long shaft this past March. I have the fuel line Tee'ed off the water/Fuel seperator, and I'm using the squeeze bulb in the line to the Motor.
Yesterday was the first time that I was able to use it on the water , the motor would run perfectly for the first little while then would just quit as if out of fuel. Squeeze the bulb a little and it would run for a minute or two and then quit again , same thing everytime. The squeeze bulb would never get firm with fuel. I'm thinking that the fuel pump on the motor might be bad, when it is getting fuel it runs perfectly .
