fuel strainer element Q
orlandoclippertim
Ok-- (RDE-17 johnson-- 25 horse seahorse 1955 ? )
I pulled the carb tonight and split it. Fairly simple looking. Not really dirty but old gaskets kind of hard.
It has a little blass bown with a fuel strainer element in the bowl. It is a little cylinder shaped thing.
It looks to hard to be foam. Not sure what it is made of. (could it be sintered brass?)
It looks like it has a heavy shellac stain on it. (like in all the pores-)
I shot it with a quick burst of carb cleaner and then compressed air. Helped a little--- but I didnt do it more because
I didnt want to dissolve it- not knowing what it is made of ......
Is this brass ? is it safe to soak (submerge overnight) in carb cleaner ? Are new ones available ???
How do I deal with this ?
Tim
Crosbyman
other than a replacement all you can do is soak it in solvent like acetone or lacquer thinner and blow dry it a few times
you can always mount an external in line filter and take out the one inside the glass bowl
they are still sold about 20$ this one fits a 1958 35hp
0302062 - Filter
orlandoclippertim
I have a couple 59 35 horse motors too-- Ill see if they have a better one I can soak.
Thanks a bunch - Ill try looking up that number (looks like a johnson number)
Tim
