madgadget
- Sep 28, 2009
- 281
Hi all,
I just picked up a merc 50hp pull start. I was told by the prev owner that he could not get it going, nor could the people at the marina he took it to. However the previous owner to him promised that it was a runner, so I did some checks and decided to take my chances. (It has compression and spark)
So I took it to my workshop put it on a stand fixed the pull start, pulled all the plugs and sprayed in some fuel, put plugs back and gave it a tug, it started and ran for about 3 seconds before dying. (I didn't hook it up to a fuel supply.)
So it runs. I then went to look at the carbs and followed the fuel lines. It goes from the intake fitting, directly over to the intake to the carbs, there is no fuel pump. Is this normal? Surely there should be some kind of pump on it somewhere?
This is where I throw it out to the experts here. Is the supply tank supposed to be pressurised by crankcase pressure to force fuel to the carbs or is there some other way this is supposed to work?
Thanks
Thanks
