hawkman222
- Feb 20, 2006
- 45
A few weeks ago I posted a question about swapping out a blown 1985 Evinrude #E90TLCOS powerhead with a 1979 Johnson #J85TL79R. Responses to my question seemed to think the swap would work. I've since learned thatthe blown powerhead is a J90TLCUS (1987) that was apparently put on my 1985 Evinrude before I bought it. I still think the 1979 85hp will work. It was sugested that I use the newer fuel system off the blown motor. It has the primer system & VRO instead of the choke with conventional fuel pump. The problem is, I'd like to use the newer intake manifold with lube recirclation on the swap but the recirculation lines come together and combine into 1 line that goes to the crankcase to lube the crank center bearing. The old (1979) crancase cover doesn't allow for this, no nipple. So, where would I run this line? If I use the old intake,there is no crankcase tap for the flame arrestor fitting going to VRO pulse line. Could I use the hole which drives the old fuel pump? I'd have to retap it (YIKES!) or use a bunch of different fittings to get what I need. Could I use the old fuel pump, the old intake and install the primer system? Would the convetional fuel pump work with the primer system?<br />Or should I just throw in the towel and use all the old fuel system off the 1979 before I break something?
